Hi all,
What is the difference between differential amplifier and fully differential amplifier?
Hi all,
In short, a differential amplifier has a differential input & single-ended output. Output = input differential * gain. You can find more details here:
Instrumentation Amplifier Video Series
For Fully differential amplifiers, both the inputs and outputs of the device are differential. Output differential = input differential * Gain. You can find more details here:
Fully Differential Amplifier Video Series
Hasan Babiker
Also, the main addition in a fully differential amplifier (kind of an odd term coined I think by Jim Karki, TI Dallas back around 1999) is an added common mode loop that forces the output differential signal to swing around a desired DC common mode voltage - big step forward in driving diff input ADC's. Many of the original FDA app notes were written by Jim.
And incidentally, that common mode loop actually allows a new (kind of breakthrough) solution that was hiding inside all FDA's undiscovered for quite some time - I pounded through the required equations while at Intersil and published in these two articles - if you need matched input impedance single to differential, what is described gives you the lowest noise solution using what I call an Active Balun solution. I did a series of videos on these as well if you are interested.
