Part Number: LM293
Other Parts Discussed in Thread: LM339, TL331, TL331B
I use pin5/6/7 but pin 1/2/3.
How to connect pin1/2/3? Floating? tie to GND?
Hello Jim,
Please see section 5.1 of the LM339 Family Application note:
https://www.ti.com/lit/an/snoaa35a/snoaa35a.pdf
My recommendation is to tie one pin 3 directly to pin 4 ( to the GND) pin, and connect pin 2 through a 1Meg resistor. The input bias current will generate a small voltage across the 1M resistor and force the output low.
The appnote adds series resistor to the inputs to limit any transient currents. If pin 3 and 4 are tied directly together - there should not be any large transient differences between them.
If you just need a single device, the TL331 or TL331B is the single channel version.
