Part Number: LM111QML
Other Parts Discussed in Thread: LM111
Hello , is your LM111 MDA die - the NSC original design.
if yes, what is the die size ? Die step ?
thanks,
Hello Sean,
I am looking into this...it may take a while.
This device was obsoleted many, many years ago, well before the TI acquisition. Locating documentation is taking a while.
Most likely it is an original National Semiconductor device. If you have access to a microscope, you should be able to see the National logos on the die if it is.
Do you want to order more? Or are you looking for a replacement? If you have devices, any info off the packaging would be helpful to us (lot#'s, date codes, etc).
The closest living relative is the LM111 MD8, which conforms to MIL-STD-883 (and is an National device):
https://www.ti.com/product/LM111QML
The die layout is on the Die datasheet:
Die D/S LM111 MD8 Voltage Comparator
Since I have not found the die ID's for the MDA to compare, I cannot say if they are identical layouts yet.
Hi Sean,
There haven't been any responses to this thread for quite some time. I will close this thread and assume you found an answer to your question.
Please respond to this thread if you need additional support on this topic.
Kind Regards,
Joe
