hello team,
I want to find a amplifier for the signal below:
Signal: 3200Mbps single-end
Output Vdc+Vac : 0.6V+1200mVpp
Gain> 4V/V
Do you have any suggestion?
Would you be able to tell us more about your application? Are you looking for a DAC first, then be using an amplifier?
Thank you,
Sima
Sorry for the delayed response. I discussed this application with the interface group, and they said these are higher speeds than their transceivers can support. I am not too sure if high speed amplifiers are the solution here, but here is a start on some products based on the specifications you listed. You can filter these products down even more using the column on the left.
Thank you,
Sima
