Other Parts Discussed in Thread: LMH5401, LMH3401
Hi Team,
Customer is looking any high speed amp that meeting below spec, any suggest one?
Thanks!
Andrew
PARAMETER |
TEST CONDITIONS |
MIN |
MAX |
UNIT |
Output voltage |
Output load=100Ω |
±1 |
Vpp |
Differential input voltage |
Gain=1V/V |
±1 |
Vpp |
Large-signal bandwidth |
Vout=2Vpp |
2 |
GHz |
Common-mode input range |
Output load=100Ω, Gain=1V/V |
±0.75 |
V |
Rise time & Fall time |
Large-signal transient response |
77 |
ps |
Common-mode rejection ratio |
1MHz |
60 |
dB |
30MHz |
50 |
dB |
1GHz |
30 |
dB |
Input-referred voltage noise |
13.26 |
nV/√Hz |
Slew rate |
12 |
V/ns |
Settling time to 1% |
Vout=2Vpp |
2 |
ns |
Input offset voltage drift |
26 |
uV/°C |
Total harmonic distortion |
f=1GHz, Vout=2Vpp |
-35 |
dB |
