Part Number: TLV341
Other Parts Discussed in Thread: TLV9001, , TLV9041
I'm surveying TLV341IDRLRG4's pin to pin alternative material.
Could you provide me the recommended parts? Thanks.
Hi Jesse,
Does your design require the shutdown functionality offered in the TLV341? If not, I recommend taking a look at the TLV9001.
I am not aware of an exact pin to pin alternative if shutdown functionality is required.
Thank you,
Tim Claycomb
Hi Jesse,
The minimum supply voltage in the datasheet is 1.8V. I cannot comment on what performance may look like below that.
If you need operation below 1.8V consider using the TLV9041. While the specs are different than the TLV9001, the TLV9041 can operate down to 1.2V.
Thank you,
Tim Claycomb
