Part Number: TLV9051
Customer is using TLV9051 in the configuration shown below.
Any concerns with the 1 uF output capacitor? We understand it is more than recommended in the data sheet.
Mark
Mark
Hi Mark,
This will cause severe stability issues. An op amp cannot directly drive 1uF. This capacitor must be removed or an isolation resistor must be added. I recommend taking a look at our TI Precision Lab Videos on Stability.
Thank you,
Tim Claycomb
Hi Mark,
using the dual feedback method results in a comfortable phase margin of 85°
Kai
Hi Kai,
Thanks for the suggestion. The customer was basically implementing a voltage regulator so we suggested an LDO. That is what they decided to use.
Mark
