(1)
What is the purpose of the PBTL Pin. Let me explain, we can set registers to create a mono signal and drive the outputs from the same channel. For example channel1 and ~Channel1 using the output drive channel (register 0x25) and achieve the same result?
(2)
TI spec recommends paralleling out A/B and C/D. Is it equally reliable to parallel A/C and B/D?
(3)
Does the performance change if the paralleling occurs AFTER the LC filter such that in PBTL mode there are 4 small inductors vs 2 large inductors?
M
