Part Number: DRV8323R
The shunt amplifier has a common mode input range of +/- 0.15V, but it is not specified with respect to which ground this is. The amplifier's output is also referenced to some ground, and to properly design the downstream analog circuits, we also need to know which ground is referenced.
Given the layout recommendations for how to connect vref, as well as the proximity to the SO pins, one would be led to believe that the shunt amplifier is referencing DGND. Is this correct?
Thanks!
