Hi team,
We are developing Audio module on IMX8MM board using TLV320AIC110 CODEC.
Currently I2C communication is working properly.
But when I connect MCLK, BCLK, WCLK from IMX8MM to TLV320AIC110EVM, I'm getting error something related to sync register.
So when we give supply to TLV board, TAS1020BPFB IC from TLV board is generating clock itself, so basically we can connect one at a time.
How to disconnect TAS1020BPFB configurations through software and hardware, Is there any way connect only external I2S signals?
If I connect I2S_ENABLE pin to 3.3v, Will external I2S be enabled?
Need your help to solve the issue, What can be done?
ONE MORE QUESTIONS:
1. Is there any way to give power supply to TLV IC instead of USB.
Divyesh.
