HI TI
When the customer is using tas5760, there is no problem with the input signal and power self inspection, but there is no output signal. The AVDD voltage is 12V. The customer has the following questions
1.SPK_ SD (pin \7) always high, is this OK?
2. to make the internal DVDD LDO output voltage, in addition to the AVDD voltage, pull high SPK_ SD, do you still rely on any other signals?
