Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TAS5806M: PVDD and Hybrid mode
Part Number: TAS5806M
hey experts,
the datasheet says at cahpter 9.4.6.3:
To use the Hybrid Modulation, users need to enter the system's PVDD value on the
TAS5806M PPC3 App.
I assume, because PPC3 needs the voltage of PVDD, also the chip itself needs to know about it. Because I do not use (and do not have PPC3) I would like to know, which registers needs to be setup with the PVDD voltage in which format to be able to switch to hybrid mode. The datasheet is no help... As always with TI's datasheets, if the is an holy application, the datasheet lacks so much informations.
best regards from germany
Micha
