Hi ti
How to understand the two input impedance descriptions in the following manual tables?
Hi ti
Hi Pdjuandi
Thank you for your support, but the above sentence can only be understood literally, not technically, so the customer does not know how to choose parameters of AC-coupling capacitor,Can you give some guidance on principle?
Normally for high fidelity audio recording you will want the cutoff frequency for the HPF as low as possible maybe 20Hz, so when the input signal is low (lowest setting) e.g. -12dB a 0.1uF with 80K will give the 20Hz cutoff which ensure the fidelity of the signal. So placing a 0.1uF cap at input is ok.
