I am working on a project and the spec calls for the use of some LP2985-33DBV regulators. However, there doesn't seem to be much of a record of these—I've found a few references on ti.com but not a ton, and no data sheets or anything.
I assume the part has been deprecated and there's a new replacement. The most common component seems to be the LP2985-33DBVR or LP2985-33DBVT, but I'd like to verify that these components are the same, as I'm seeing some indications online that they may have different pinouts than the LP2985-33DBVR.
What is the recommended drop-in replacement for the LP2985-33DBV? Unfortunately, I need a direct replacement as I'm using older gerber files that can't be modified.
Thanks!!
