Hi team,
What is the ABS MAX voltage at VO+/- pins?
The datasheet doesn't describes the spec, so that actual resistance voltage can be helpful for me.
Best Regards, Taki
Hi team,
Best Regards, Taki
Hi Taki,
Do you want to know what is the maximum voltage coming out of VO+/- pins? You may consider VDD as abs max; this would be slightly below whatever VDD voltage is. You can refer to typical values provided in data sheet:
-Ivan Salazar
Applications Engineer
Hi Ivan-san,
Thank you for your answer.
What I want to know is allowable maximum voltage coming in of VO +/- pins in the case of ground fault, power fault or any fault conditions in speaker side.
Should it be -0.3V to VDD+0.3V or something?
Best Regards, Taki
Hi Taki,
Thanks for clarifying, you're correct in that case it would be -0.3V to VDD+0.3V, similar to input pins abs max range.
-Ivan Salazar
