My application needs a 4 channel @ 2 ohms amplifier, with the possibility to wire the amp to work in btl mode at 4 ohms load.
Is it possible to use a split power supply or other means to avoid using large capacitors in the output in single ended configuration?
Thanks.
Fabiano
