Part Number: OPA1656
Other Parts Discussed in Thread: PCM5242
Hello TI-Team,
We have a problem with the noise at the output of our DSP board. We want to ensure that the noise is not coming from our output circuitry by evaluating the performance of used ICs. The output is converted with the DAC PCM5242. The analog audio signal is then amplified with the OPA1656ID operational amplifier. Our question is whether the noise problem is due to incorrect configuration of the DAC or OPA.
Has the OPA been correctly dimensioned with regard to noise? I only have the reference in the data sheet under 8.1.1 Basic Noise Calculations.
Another question is whether an impedance adjustment must be made between the two ICs in order to keep the noise floor as low as possible?
I have attached a schematic page with the DAC and the OPA used.
Thank you for your support!
Best regards
Emanuel Lemnitz
