Hello
There are two questions would like to know.
1. Is it safe to connect the output to ground(maybe caused by mistake such as connecting the output to single ended amplifier, the negative signal will be connected to ground.)
The calculation of the current would be 2.1Vrms/470R = 4.47ma? If so, what is the safe current limited of PCM5242?(not getting damaged)
2. Is there any reference for choosing the value of resistor?(ignore the cutoff frequency becasue it can be set by capacitor) How does it affect the distortion and harmonics? Can it be 100R or even 10R?
Thank you very much!
