LM3886: power supply question
Part Number: LM3886
Hi team,
is there any power sequences requirements for LM3886?  customer plan to use 18V as positive voltage and -48V as negative voltage. But for power up sequences, there is no specific requirements. Could you pls help to comment on the power sequences requirements for supply voltage? Thanks!
Rayna
  • Hi Rayna,
    There's no specific power sequence for this device. Based on the data sheet explanation, it also says that under-voltage protection helps to bring up the device in a known state after the supplies are fully powered up.
    -Ivan Salazar
    Applications Engineer
