Other Parts Discussed in Thread: PCM5100A, TPA3251, TAD5112
Two questions on TAD5142.
1. If operating in slave mode (I assume this is what is meant by target mode), can TAD5142 operate at sampling frequencies off of the normal audio rates? For example, if I feed TAD5142 with FS=104kHz and bitclock=64*104kHz=6.656MHz, will that work properly? I do this now with PCM5100A.
2. Does TI have any recommendation on suitability for TAD5142 directly driving the input of TPA3251 class-D amplifier? Any example schematics? I currently use PCM5100A + 2x op-amps to feed TPA3251, and it would be great to compress that all down to TAD5142.
