PCM2902C audio DAC to USB question
Other Parts Discussed in Thread: PCM2902C, PCM2902, PCM2906C
Hi Team,
customer is evaluate the PCM2902C for audio DAC with USB interface, and they want to know if it needs any USB software driver effort on Linux or Android OS? Please advise. Thanks.
Arthur
  • Hi Arthur,
    PCM2902C is a standard USB Audio Class device, it doesn't need special drivers as it is automatically recognized by the host system.
    Linux systems usually use ALSA driver to interface with USB Audio devices.
    PCM2902C is a slave device so you must be sure that the host system can act as master.
    -Ivan Salazar
    Texas Instruments
  • Hi Ivan,
    Customer tried PCM2902 EVM board on TX1,86-linux or Windows, but it can't function normal. Attached are the error message, can you please advise if there is any special setting for getting the board working? Thanks.
    Arthur
  • Hi Arthur,
    Could you share your schematic so I can look for any possible hardware issues?
    If you don't want to post it in the forum you can send it to my address: ivan.salazar@ti.com
    -Ivan Salazar
    Texas Instruments
  • Hi Ivan,
    customer is used PCM2902C EVM board for testing, and they got problem on Windows10 and Linux environment that both OS can't recognized the device(please refer to the error messages on my previous posted mail). can you please advise if PCM2902C EVM need any software driver or setting for function working on Windows10 or Linux?
    Thanks.
    Arthur
  • Hi Arthur,
    I'll verify the operation of PCM2902C EVM.
    I'll come back later today.
    -Ivan Salazar
    Texas Instruments
  • Hi Ivan,
    I've tested the PCM2906C EVM board on Windows8, the device maanger shown unknow device. Please advise if it need any HW setting or software driver on Windows8/Windows10 OS? Thanks.
    Arthur
  • Arthur,
    I have connected a PCM2902C EVM board to Windows 10 system and the device is being recognized and I get good sound.
    Are you shorting all the jumpers on CN002? (This is default connection of CN002)
    -Ivan Salazar
    Texas Instruments
