Hi Team,
My customer would like to evaluate TAS5719. For the DVD and PVDD, cusotmer would like to know the analog and digital power/ ground separation inside of chipset.
Could you provide your comment for this gnd layout?
SHH
Hi Team,
SHH
Hi SHH,
To confirm, this is a question about the internal layout of the TAS5719 and not PCB layout? I will need to check with design about this, if you can provide some more details this would be very helpful to minimize back and forth. You mentioned power and ground. Which nodes exactly would you like me to ask about? (e.g. DVDD,DVSS,AVDD, etc.)
Alex
Hi SHH,
PGND is used for all grounds on the EVM so it looks like it is okay to short them together. However, I would like to double check with design about this.
Alex
Hi SHH,
Following up, the grounds are separate on the chip. However, they should be shorted together on the PCB as shown in the EVM. The one exception is AVSS, which is used for the PLL circuitry. This can be routed separately. You can also see that this is done on the EVM.
Alex
