Other Parts Discussed in Thread: TPA3136D2
From my recent thread about the audio demo,
While some switching noise is acceptable on one end of the resistive load, I'm seeing nearly
1 V p-p switching noise on the output waveform. Ideally, this should not be more than 250 mV p-p.
This is a problem, that may likely only be test bench related. A loudspeaker load (no LC filter) sounds
raspy, indicating that the differential output still has noise in it. I will be checking once more with
a new loudspeaker. In the product, this loudspeaker cable length can be as long as 4.5 feet.
I will take any new pointers for the testbench.
The LC filter I was using with the resistive load broke an inductor leg. Can I have a through hole
part number for inductor L1 from page 17, Figure 19 of the TPA3136D2 datasheet?
Priya
The inductor in the LC filter broke.
