Other Parts Discussed in Thread: TAS5711
hi
Q1:how is the power consumption at PDN low active(Reset high deactivated)? Datasheet do not show.
Q2:Is it the same when enter shutdown by setting register 0x05?
Q3:As for TAS5780,when I set the powerdown mode and leave powerdown mode. Do the audio play back immediately like TAS5711(no other register set needed)? Do the DSP register retained in powerdown mode.
Q4:if TAS5711 power consumption at PDN is x mA, why is so larger then TAS5780(x uA)。
thanks a lot.
