Other Parts Discussed in Thread: TAS5538
Hi TI,
In our factory, we need to read TAS5534 ID from register which is constant value to check TAS5534 IC is available or not.
I have checked the datasheet of TAS5534, there is 0x01(General status register) which default value is 0x03.
The problem is what we read the constant value is 0x01 from 0x01 register by I2c read command.
Could you help to check that? Or, except 0x01 register, is there other register we can read ? if the value of the register is constant will be good enough for us.
Thanks.
Vick
