Looking for info, appnotes, etc. on output characteristics during shutdown. With head phone like loads (using the eval board) the output seems controlled and quiet. With higher load impedances (100k) the output during shutdown is noisy (white+?) and has audio input bleed thru. A 10k resistor to GND in parallel with the load helps significantly, but this seems like a poor solution to help quite "off time". Any workarounds?
Thanks!
