Hey,
I have some questions regarding the TPA3255EVM:
- to run the amp in mono PBTL mode and send it a single ended signal to input A, do I ground the B channel? or does the input need to be differential?
- also are the power specification in the data sheet peak power or rms
- and on the data sheet it calls for 470uF capacitors on PVDD, but the EVM uses 4700uF, what is recommended?
Thanks!
