Customer has design with DIT4096 using the recommended circuit from the data sheet; i.e. tranformer coupled to RCA connector. When they connect to a SPDIF chip it does not recognize the communication. The output pulses have a lot of noise and seems to drifts. When they change the output design to match the circuit in the PCM4201 EVM it appears to be working; output coupled via a resistor divider network.
The transformer coupled design would seem to be a good idea to avoid ground loops and provide isolation. Any suggestions as to why the transformer coupled design did not work. Also, I would like a little G2 on why you would choose one method over the other.
Thks,
Clay
