Dear TI Team,
If you lower the PCM Software volume on the TAS2652, you will experience a loss of output.
Amp Can you tell me which point to check in the setting?
The following is the register setting.
/ # i2cdump -f -y -r 0x00-0xf0 2 0x4c
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 00 00 0c 34 cf 22 09 03 30 10 01 42 40 04 05 06 ..?4?"??0??B@???
10: 07 14 12 76 01 2e 60 0e 0c 00 fc a6 df ef ff 00 ???v?.`??.????..
20: 00 11 00 00 04 00 11 80 00 50 4f 40 7a d2 80 a4 .?..?.??.PO@z???
30: 19 40 81 34 4b 78 04 00 0c 08 2e 38 3c 08 10 00 ?@?4Kx?.??.8<??.
40: 76 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 v...............
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
70: 00 00 00 ff 00 ff 00 00 cc 00 00 00 00 10 43 00 ........?....?C.
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00
Thanks.
