Hello TI engineer,
I am now designing a Audio Decode with PCM1794. Absolutely lowing distortion Is the most important thing in designing.
Firstly, I understand that perfect power supply Is important and so Is impendence parity and layout shelding.
The question comes from System clock, meanly MCLK supplied to DAC. Is it true that as long as the MCLK Is perfect enough and jitter of I2Ss are not large enough to induce data mistake, The analog output will be idealy perfect?
For example, if the mclk Is 24Mhz, jitter of I2S Is several periods of the MCLK, Can DAC correct such jitter from LRCK SCLK and Data route of I2S?
That would be a great help If there are relative documents as well as lines of answers #^_^#
Best wishes,
Louie LI
