Hi Sirs,
The table 55 is not in line with table 94 of the TAS2563 datasheet. My measurement result on the EVM shows the TAS2563 can send up to 7.923Vrms (11.204Vpk) which is close to the chart of the table 55.
Would you please advise if the table 94 needed to be updated?
TAS2563EVM Test Result with 13V PVDD, 4ohm load and Boost Off,
# Set TAS2563 Amp_Level = 19dBV (12.60419Vpk)
w 90 00 00
w 90 7f 00
w 90 03 2c
TAS2563 datasheet table 55 -> Register 0x03, 0x15~0x1F reserved
TAS2563 datasheet table 94 -> Register 0x03, 0x15 ~ 0x1D were defined
Thank you and Best regards,
Wayne Chen
09/07/2020
