Other Parts Discussed in Thread: TAS5805
Hi Team,
My customer is using TAS5805 and has some AGL issues.
1. With -12dBFs input, the power is set to 7 watts. The big signal uses 0dBFs, enable AGL and the power can be limited to 7 watts.
2. With -15dBFs input, the power is set to 7 watts. The big signal uses 0dBFs, enable AGL (same AGL params as above) and the power can only be limited to 9 watts.
AGL params:
