Hi Sir,
No audio playing but Speaker sound pressure is over during the EMC Conducted Disturbances Immunity Test.
Please see below results. Please advise how to add filters into the below circutis to block the noise. Thank you. Eric Fu
Hi Sir,
Hi, Eric,
Could you attach the pictures again, please? Unfortunately, I am not able to see the pictures you mentioned.
Could you provide the TPA6211A1 schematic portion in order to have a better approach to this case?
Thank you.
Luis Fernando Rodríguez S.
Hi, Eric,
I just saw you post the pictures. I will take a look at them and provide my feedback as soon as possible.
Hi, Eric,
I would suggest to try using an LC filter in order to filter the high-frequency noise. I recommend to take a look at the document and tool below for a proper filter configuration based on what you require.
https://www.ti.com/lit/an/slaa701a/slaa701a.pdf
https://www.ti.com/tool/LCFILTER-CALC-TOOL
Please let me know if you have additional questions or comments.
Hi Sir,
Thank you very much for the information.
We will modify the circuit and test again.
We will also reduce the Amp gain and check if the speaker quality(it may be damaged by over rating operating).
Eric Fu
Thank you for your response, Eric.
I will close this e2e thread for now. But feel free to post your results in this thread. We will be glad to help you in case you have additional questions.
