Part Number: TLC555
Hello
I designed the circuit with TLC555 as below image.
I had a problem with output without TRG signal during testing.
Green (U17-3Pin), Purple(U17-2Pin)
What is the cause of the output when there is no TRG signal?
Best regards.
Part Number: TLC555
Hello
Best regards.
Hi Louis,
Can you probe the supply line when the extra output pulse occurs. It may be helpful to add an additional 1uF bypass capacitor to your supply.
Hi Louis,
Just for clarification, was there an incorrect output during the waveform of the power supply you attached in the last image? I'd like to see what the VCC at the TLC555 looks like at the same time an incorrect output occurs. The TLC555 recommends a 0.1uF and a 1uF capacitor on the supply placed near the timer. This is a problem we see occasionally and it's usually attributed to power supply noise.
