Other Parts Discussed in Thread: NE555
Does TI have the similar NE555 reference design for the application in below?
- TRIG V=1/3VDD
- VOUT = 12
- Delay 2 mins
Thanks.
Thanks.
Jack,
Are you looking for astable operation or monostable?
Hello Chris,
Thanks for the reply.
I am looking for astable operation. Thank you.
Jack,
I have put together a simulation (attached at the bottom) for the A-stable configuration. In order to achieve the delay you will want to control the reset pin with a known voltage that could come from a microcontroller. In the simulation I have used a time controlled switch in order to show the delay function.
You can see below, the delay I used is 5ms for demonstration purposes. The trigger occurs at 5V or 1/3VDD.
