LMX2594EVM: LMX2594
Part Number: LMX2594EVM
Other Parts Discussed in Thread: LMX2594
With regard the 3.3V power supply at the moment we use a bench supply, some wires and an SMA connector. Our set-up doesn't seem the most professional... On your website you have a picture of 3.3V being supplied by a Coax. Does TI supply a DC-DC voltage supply with coax connection that could drop right in? What are the specs [if any] on incoming ripple, etc, on the DC.
With regard the grounding 3.3V, when we the LMX2594 in Single-Ended then I think the potential on the OD of the outbound Coax will be the same ground as provided by the 3.3V and the RF stays on the ID of the coax, yes? I.e. no common-mode sent down the output.
Thanks, John
