Part Number: CDCE72010
I plan to drive PRI_REF with LVCMOS signal, meaning grounding the PRI_REF- with 1kOhm resistor as recommended in the datasheet.
However, I'm not sure what is the level of the signal that I should configure for PRI_REF+ while PRI_REF- is grounded?
The datasheet only shows the level for PRI_REF in differential mode but not the level for PRI_REF configured as LVCMOS.
Please help.
Thanks.
