Part Number: CDCI6214
Hi:
I am using CDCI6214 to generate 4 clocks. By now I can generate the register setting hex vaule using TICS PRO. BUT I failed to program the CDCI6214 through I2C interface. REFSEL signal is low, EEPROMSEL signal is high, so the device select EEPROM page in page1, and this is a I2C interface by default. However, to program the EEPROM by Direct Access, this would require a prepared 64 words EEPROM file. How can I generate a EPROM file?
