Part Number: LMX2820
Hi team,
Can you know the max & min frequency hopping time LMX2820 can support.
How fast it can do frequency hopping?
Is there any tool/way through which we can calculates no of hopps?
Hi team,
Hi Shivakant,
LMX2820 supports the instant calibration feature, which reduces the VCO calibration time and overall fast frequency hopping.
Datasheet shows the VCO cal timing 2.5usec and follow the section 8.1.3 for instant calibration procedure.
Ajeet Pal
Hi Ajeet,
Thanks for your reply.
Actually fast switching(hopping) depends other factor too like Analog loop filter settling time, programming time etc.
So i just want to know if including instant VCO calibration time of 2.5us , what will be the max & min locking time we can expect?
& one thing more: based on loop filter BW, how to calculate loop filter settling time in case of LMX2820?
Hi Shivakant,
As you mentioned correctly, analog lock time depends on loop filter BW and as a thumb rule analog lock time can be 4times of loop filter BW time period based on settling tolerance frequency say 10kHz.
You can use the PLLatinum Sim tool to calculate the loop BW and see the lock time.
https://www.ti.com/tool/PLLATINUMSIM-SW
Ajeet Pal
Hi Ajeet,
Can you suggest what min phase margin i can consider for this loop filter design?
I have seen that for few filter BW, performance interns of jitter & lock in time is better at <45 degree phase margin should i go with this? or i have to consider > 60 degree phase margin?
just for example:
Hi Shivakant,
Usually you can go for higher loop bandwidth around 350kHz and phase margin 70deg for optimized phase noise performance.
LMX2820EVM using the same loop BW settings and you can validate the settling time with it.
Ajeet Pal
