Part Number: CDCI6214
Other Parts Discussed in Thread: LMX2594
We are using CDCI6214 in Fallback mode. So if I understood correctly from the Figure 91 of the datasheet, during the initialization:
-We need to make sure that EXT_PLL_RESET_N kept low.
-After the reset is released, the control pins (and GENERIC0, GENERIC1, GENERIC2 and GENERIC3 registers) should be set.
-Then, the PLL0, PLL1, PLL2, PLL4 registers should be set.
-Then the STARTUP registers should be set.
The questions: What should we do for bypassing the VCO calibration and bypassing synchronization? How long does the calibration take?
