Other Parts Discussed in Thread: LMX2581, CODELOADER, USB2ANY
I am having trouble getting any RF signal out of the LMX2581EVM.
The hardware has been reconfigured to take a reference signal from an external clock at 10 MHz (per information given in the LMX2581 Users Guide and Datasheet).
I've adjusted the relevant settings in CodeLoader to account for the fact that the device should be taking an external reference instead of using its internal VCO.
However, I'm getting no RF signal out of the device.
I'm wondering if this is due to some other setting in CodeLoader that must be enabled prior to seeing a signal.
Is there a minimum series of steps that absolutely must be taken in CodeLoader in order to produce an RF output signal?
Thank you.
Chris
