Part Number: LMK03328
Updated REVID to be 0x02 (was 0x01)
->What has changed from 0x01 to 0x02?
Please check and advice.
Hello Miyairi,
This is a minor change to remove an internally synchronized delay reset. There is no change to device performance or datasheet specifications.
This change ensures proper device power up sequence.
regards,
Julian
Hi Julian,
Thank you for reply.
By the way, it mean are there any risk for device power up sequence, if we continue to use REVID 0x01?
If the device power up sequence is not normal, can I see any sign from the device?
Miyairi
Hello Miyairi,
TI ships only REVID 0x02 material, therefore you should not get the older material anymore.
On the older material only a fast PDN pin toggling from High to low to high can be erroneous. Normal startups are not affected.
regards,
Julian
