LMX2592: Lowest Possible Phase Noise at 9GHz 10KHz Offset
Part Number: LMX2592
With our implementation of a transceiver the lowest phase noise we could achieve is -96dBc/Hz at 10KHz offset of a 9GHz carrier. The amplifiers on the chains have phase noise better than -130dBc/Hz. The LMX2592 reference is an OCXO with phase noise of -170dBc/Hz at 10 KHz offset. The power supply used is an "ultra low noise" one. Is this the best the LMX2592 could do?
Thanks for your usual excellent support.
Randy
