LMX2595EVM: LMX2595EVM
Part Number: LMX2595EVM
Other Parts Discussed in Thread: LMX2595
Hi team,
In my application I need to use external reference signal. I have changed the configuration of LMX2595 EVM and tried feeding it with external reference signal. As suggested in EVM manual for single ended external clock I have populated R25 51 ohm with 47 ohm, Will that make any difference in output frequency. I have loaded the register values but the output frequency is shifted by 500 MHz. Should the resistance value be exactly at 51ohm?
Thank you in Advance
