Other Parts Discussed in Thread: LMK61E2,
Hi Team,
We are using this chipset to provide external clock to video unit for display.
I have checked but no Linux kernel driver is available.
Do you have linux kernel driver available for mention chipset? If yes then can you please share the driver or path in existing linux kernel codebase.
Our purpose is to set the 90MHZ clock output clock which will be given to the video unit.
For this, we need to set the PLL and other configuration of this chipset.
Can you please share the register configuration require to achive the 90MHZ output clock?
What will be the clock generated from the chipset?
NOTE: We are able to detect this chipset over I2C verified using the i2cdetect utility and able to read register of chipset using i2c utility.
Thanks & Regards,
Dhaval
