LMK04610:10MHz reference clock of PLL1 configuration
Part Number: LMK04610
Please can provide assistance in the configuration for the LMK04610.
The Input clock is (CLK0) 10MHz. The External VCXO is 122.88MHz. The output clock is 122.88MHz.
Currently, PLL1 didn't lock of 10MHz of the input clock. If the input clock changes to 122.88MHz that is PLL1 locked.
What are the correct settings for the input clock 10MHz in this case?
Thanks in advance!
    To lock PLL1 with the 10MHz reference input and 122.88MHz VCXO, your PFD frequency should be greatest common divisor of both frequencies, which should be 80kHz.
    Hence, you need to change CLKIN0_PLL1_RDIV value to "125" and PLL1_NDIV value to "1536" in PLL1 section. With these updates, PLL1 should lock for 10MHz input reference at CLKin0.
    Thanks!
    Ajeet Pal
  • Dear Ajeet,
    I have set the CLKIN0_PLL1_RDIV value to "125" and the PLL1_NDIV value to "1536" in PLL1 section, but it is unlocked on PLL1.
    My configure as below:
    [SETUP]
    ADDRESS=888
    CLOCK=8
    DATA=4
    LE=2
    PART=LMK04610
    IFACE=SPI_CLKLOW
    ADDRESS_I2C=0x0
    [PINS]
    PINNAME00=SYNC
    LOCATION00=7
    PINVALUE00=False
    PINNAME01=RESETN
    LOCATION01=3
    PINVALUE01=True
    PINNAME02=CLKIN_SEL
    LOCATION02=1
    PINVALUE02=False
    [MODES]
    NAME00=R0
    VALUE00=0
    NAME01=R1
    VALUE01=256
    NAME02=R2
    VALUE02=512
    NAME03=R3
    VALUE03=838
    NAME04=R4
    VALUE04=1080
    NAME05=R5
    VALUE05=1283
    NAME06=R6
    VALUE06=1553
    NAME07=R7
    VALUE07=1792
    NAME08=R8
    VALUE08=2048
    NAME09=R9
    VALUE09=2304
    NAME10=R10
    VALUE10=2560
    NAME11=R11
    VALUE11=2816
    NAME12=R12
    VALUE12=3153
    NAME13=R13
    VALUE13=3336
    NAME14=R14
    VALUE14=3584
    NAME15=R15
    VALUE15=3840
    NAME16=R16
    VALUE16=4127
    NAME17=R17
    VALUE17=4352
    NAME18=R18
    VALUE18=4612
    NAME19=R19
    VALUE19=4880
    NAME20=R20
    VALUE20=5248
    NAME21=R21
    VALUE21=5384
    NAME22=R22
    VALUE22=5712
    NAME23=R23
    VALUE23=5888
    NAME24=R24
    VALUE24=6144
    NAME25=R25
    VALUE25=6417
    NAME26=R26
    VALUE26=6666
    NAME27=R31
    VALUE27=7936
    NAME28=R32
    VALUE28=8435
    NAME29=R33
    VALUE29=8459
    NAME30=R34
    VALUE30=8952
    NAME31=R39
    VALUE31=10004
    NAME32=R40
    VALUE32=10368
    NAME33=R41
    VALUE33=10516
    NAME34=R42
    VALUE34=10880
    NAME35=R43
    VALUE35=11008
    NAME36=R44
    VALUE36=11328
    NAME37=R45
    VALUE37=11520
    NAME38=R46
    VALUE38=11798
    NAME39=R47
    VALUE39=12033
    NAME40=R48
    VALUE40=12289
    NAME41=R49
    VALUE41=12556
    NAME42=R50
    VALUE42=12800
    NAME43=R51
    VALUE43=13056
    NAME44=R52
    VALUE44=13411
    NAME45=R53
    VALUE45=13568
    NAME46=R54
    VALUE46=13827
    NAME47=R55
    VALUE47=14080
    NAME48=R56
    VALUE48=14435
    NAME49=R57
    VALUE49=14592
    NAME50=R58
    VALUE50=14851
    NAME51=R59
    VALUE51=15104
    NAME52=R60
    VALUE52=15459
    NAME53=R61
    VALUE53=15616
    NAME54=R62
    VALUE54=15971
    NAME55=R63
    VALUE55=16128
    NAME56=R64
    VALUE56=16387
    NAME57=R65
    VALUE57=16640
    NAME58=R66
    VALUE58=16899
    NAME59=R67
    VALUE59=17152
    NAME60=R68
    VALUE60=17416
    NAME61=R69
    VALUE61=17664
    NAME62=R70
    VALUE62=17928
    NAME63=R71
    VALUE63=18176
    NAME64=R72
    VALUE64=18440
    NAME65=R73
    VALUE65=18688
    NAME66=R74
    VALUE66=18952
    NAME67=R75
    VALUE67=19200
    NAME68=R76
    VALUE68=19464
    NAME69=R77
    VALUE69=19712
    NAME70=R78
    VALUE70=19976
    NAME71=R79
    VALUE71=20224
    NAME72=R80
    VALUE72=20488
    NAME73=R81
    VALUE73=20736
    NAME74=R82
    VALUE74=21000
    NAME75=R83
    VALUE75=21248
    NAME76=R84
    VALUE76=21520
    NAME77=R85
    VALUE77=21760
    NAME78=R86
    VALUE78=22031
    NAME79=R87
    VALUE79=22272
    NAME80=R88
    VALUE80=22591
    NAME81=R89
    VALUE81=23034
    NAME82=R90
    VALUE82=23073
    NAME83=R91
    VALUE83=23360
    NAME84=R92
    VALUE84=23754
    NAME85=R93
    VALUE85=23822
    NAME86=R94
    VALUE86=24230
    NAME87=R95
    VALUE87=24320
    NAME88=R96
    VALUE88=24576
    NAME89=R97
    VALUE89=24843
    NAME90=R98
    VALUE90=25336
    NAME91=R99
    VALUE91=25344
    NAME92=R100
    VALUE92=25664
    NAME93=R101
    VALUE93=25856
    NAME94=R102
    VALUE94=26112
    NAME95=R103
    VALUE95=26368
    NAME96=R104
    VALUE96=26624
    NAME97=R105
    VALUE97=26880
    NAME98=R106
    VALUE98=27145
    NAME99=R107
    VALUE99=27393
    NAME100=R108
    VALUE100=27648
    NAME101=R109
    VALUE101=27944
    NAME102=R110
    VALUE102=28187
    NAME103=R111
    VALUE103=28418
    NAME104=R112
    VALUE104=28672
    NAME105=R113
    VALUE105=28928
    NAME106=R114
    VALUE106=29204
    NAME107=R115
    VALUE107=29440
    NAME108=R116
    VALUE108=29700
    NAME109=R117
    VALUE109=29952
    NAME110=R118
    VALUE110=30209
    NAME111=R119
    VALUE111=30465
    NAME112=R120
    VALUE112=30975
    NAME113=R121
    VALUE113=30976
    NAME114=R122
    VALUE114=31366
    NAME115=R123
    VALUE115=31648
    NAME116=R124
    VALUE116=31752
    NAME117=R125
    VALUE117=32000
    NAME118=R126
    VALUE118=32256
    NAME119=R127
    VALUE119=32564
    NAME120=R128
    VALUE120=32778
    NAME121=R129
    VALUE121=33024
    NAME122=R130
    VALUE122=33280
    NAME123=R131
    VALUE123=33536
    NAME124=R132
    VALUE124=33807
    NAME125=R133
    VALUE125=34049
    NAME126=R134
    VALUE126=34305
    NAME127=R135
    VALUE127=34560
    NAME128=R136
    VALUE128=34880
    NAME129=R137
    VALUE129=35072
    NAME130=R138
    VALUE130=35328
    NAME131=R139
    VALUE131=35648
    NAME132=R140
    VALUE132=35840
    NAME133=R141
    VALUE133=36096
    NAME134=R142
    VALUE134=36352
    NAME135=R143
    VALUE135=36672
    NAME136=R144
    VALUE136=36864
    NAME137=R145
    VALUE137=37120
    NAME138=R146
    VALUE138=37504
    NAME139=R147
    VALUE139=37760
    NAME140=R148
    VALUE140=37892
    NAME141=R149
    VALUE141=38159
    NAME142=R150
    VALUE142=38416
    NAME143=R151
    VALUE143=38688
    NAME144=R152
    VALUE144=38944
    NAME145=R153
    VALUE145=39296
    NAME146=R155
    VALUE146=39680
    NAME147=R156
    VALUE147=39968
    NAME148=R171
    VALUE148=43776
    NAME149=R172
    VALUE149=44032
    NAME150=R173
    VALUE150=44288
    NAME151=R175
    VALUE151=44800
    NAME152=R176
    VALUE152=45057
    NAME153=R190
    VALUE153=48643
    NAME154=R246
    VALUE154=62976
    NAME155=R247
    VALUE155=63232
    NAME156=R249
    VALUE156=63751
    NAME157=R250
    VALUE157=64215
    NAME158=R252
    VALUE158=64512
    NAME159=R253
    VALUE159=64768
    NAME160=R254
    VALUE160=65024
    NAME161=R255
    VALUE161=65280
    NAME162=R256
    VALUE162=65536
    NAME163=R257
    VALUE163=65792
    NAME164=R258
    VALUE164=66048
    NAME165=R259
    VALUE165=66304
    NAME166=R260
    VALUE166=66560
    NAME167=R261
    VALUE167=66816
    NAME168=R262
    VALUE168=67072
    NAME169=R263
    VALUE169=67328
    NAME170=R264
    VALUE170=67584
    NAME171=R265
    VALUE171=67840
    NAME172=R266
    VALUE172=68096
    NAME173=R267
    VALUE173=68352
    NAME174=R269
    VALUE174=68864
    NAME175=R270
    VALUE175=69120
    NAME176=R272
    VALUE176=69632
    NAME177=R273
    VALUE177=69888
    NAME178=R274
    VALUE178=70144
    NAME179=R277
    VALUE179=70912
    NAME180=R278
    VALUE180=71168
    NAME181=R279
    VALUE181=71424
    NAME182=R281
    VALUE182=71936
    NAME183=R282
    VALUE183=72192
    NAME184=R292
    VALUE184=74760
    NAME185=R295
    VALUE185=75524
    NAME186=R296
    VALUE186=75777
    NAME187=R297
    VALUE187=76037
    NAME188=R298
    VALUE188=76289
    NAME189=R299
    VALUE189=76548
    NAME190=R300
    VALUE190=76805
    NAME191=R301
    VALUE191=77060
    NAME192=R302
    VALUE192=77313
    NAME193=R304
    VALUE193=77829
    NAME194=R305
    VALUE194=78085
    NAME195=R307
    VALUE195=78597
    NAME196=R308
    VALUE196=78853
    NAME197=R309
    VALUE197=79109
    NAME198=R312
    VALUE198=79877
    NAME199=R313
    VALUE199=80133
    NAME200=R314
    VALUE200=80389
    NAME201=R316
    VALUE201=80901
    NAME202=R317
    VALUE202=81157
    NAME203=R320
    VALUE203=81930
    NAME204=R321
    VALUE204=82185
    NAME205=R322
    VALUE205=82496
    NAME206=R323
    VALUE206=82688
    NAME207=R325
    VALUE207=83200
    NAME208=R326
    VALUE208=83516
    NAME209=R329
    VALUE209=84224
    NAME210=R330
    VALUE210=84480
    NAME211=R331
    VALUE211=84736
    NAME212=R332
    VALUE212=84992
    NAME213=R334
    VALUE213=85504
    NAME214=R336
    VALUE214=86016
    NAME215=R337
    VALUE215=86292
    NAME216=R338
    VALUE216=86543
    NAME217=R339
    VALUE217=86784
    [FLEX]
    FLOW_MODE_BYP1=0
    FLOW_MODE_BYP2A=0
    FLOW_MODE_BYP2B=0
    FLOW_MODE_CPSL2O=0
    FLOW_MODE_CPSL2P=0
    FLOW_MODE_OPSL2O=0
    FLOW_MODE_OPSL2P=0
    FLOW_MODE_PDLO=0
    FLOW_MODE_PDLP=0
    FLOW_MODE_PSL1O=0
    FLOW_MODE_PSL1P=0
    BTN_DEV_STARTUP=BTN_DEV_STARTUP
    BTN_GET_SILICON=BTN_GET_SILICON
    BTN_GET_STATUS=BTN_GET_STATUS
    BTN_SWRST=BTN_SWRST
    BTN_UPDATE_VERSION=BTN_UPDATE_VERSION
    TICS_VERSION=1.7.0.0, 09-Jan-20 INI:2018-08-10, v1.0.1 PY:20170518
    TICS_VERSION_NOTE=File from an earlier device profile loaded. Would like like to update the TCS file?
    EVM_CLKin0_FREQ=10
    EVM_CLKin0_SE=1
    EVM_CLKin1_FREQ=122.88
    EVM_CLKin1_SE=1
    EVM_CLKout10_Info=Powerdown
    EVM_CLKout10_freq=0
    EVM_CLKout1_Info=HSDS
    EVM_CLKout1_freq=122.88
    EVM_CLKout2_Info=Powerdown
    EVM_CLKout2_freq=0
    EVM_CLKout3_Info=Powerdown
    EVM_CLKout3_freq=0
    EVM_CLKout4_Info=HSDS
    EVM_CLKout4_freq=122.88
    EVM_CLKout5_Info=Powerdown
    EVM_CLKout5_freq=0
    EVM_CLKout6_Info=HSDS
    EVM_CLKout6_freq=122.88
    EVM_CLKout7_Info=Powerdown
    EVM_CLKout7_freq=0
    EVM_CLKout8_Info=HSDS
    EVM_CLKout8_freq=122.88
    EVM_CLKout9_Info=Powerdown
    EVM_CLKout9_freq=0
    EVM_DEVICE_TOPMARK=LMK04610
    EVM_OSCin_FREQ=122.88
    EVM_OSCin_SE=1
    EVM_OSCout_Info=Powerdown
    EVM_OSCout_freq=122.88
    EVM_VCTRL=0
    BTN_GET_CLKMUX=BTN_GET_CLKMUX
    BTN_GET_STORAGE=Read Storagecell
    BTN_MAIL_LF1=Request Support @ TI
    BTN_PLL1_NDIV_SWRST=RST
    BTN_PLL1_RDIV_SWRST=RST
    BTN_PLL1_SWRST=RST
    CLKIN0_FREQ=10
    CLKIN1_FREQ=122.88
    INPUT_CLKIN0_PLL1_RDIV=125
    INPUT_CLKIN1_PLL1_RDIV=1536
    INPUT_PLL1_NDIV=1536
    PFDCLKIN0_freq=0.08
    PFDCLKIN1_freq=0.08
    PFDCLKIN_freq=0.08
    PLL1_EN_TIE_LOWCNT=1
    PLL1_STORAGE_CELL_7t0=
    VCXOPLL1_FREQ=122.88
    BTN_GET_PINSEL_DIV=Read
    BTN_OSCOUT_SWRST=RST
    OSCOUT_DRV_CURR_HCSL=0
    OSCOUT_DRV_MODE1_TEXT=DRV_CURR
    OSCOUT_DRV_MODE2_TEXT=DRV_RLOAD
    OSCOUT_DRV_MODE3_TEXT=DRV_MUTE
    OSCOUT_DRV_MUTE_HCSL=0
    OSCOUT_DRV_MUTE_HCSL_OPEN=0
    OSCOUT_DRV_RLOAD_HCSL_16mA=0
    OSCOUT_DRV_RLOAD_HCSL_4mA=0
    OSCOUT_DRV_RLOAD_HCSL_6_8mA=0
    OSCOUT_PINSEL_DIV_VALUE=0
    BTN_GET_STATUS_HOLDOVER=BTN_GET_STATUS_HOLDOVER
    BTN_PLL1_HOLDOVERCNT_SWRST=RST
    BTN_PLL1_HOLDOVER_DLD_SWRST=RST
    BTN_PLL1_HOLDOVER_LOCKDET_SWRST=RST
    HOLDOVER_DLD_COPY=0
    HOLDOVER_ERROR=For a proper function, the Digital Clock must \nbe switched on.
    HOLDOVER_LOL_COPY=0
    HOLDOVER_LOS_COPY=0
    PLL1_HOLDOVER_MAX_CNT_SECONDS=1
    PLL1_HOLDOVER_MAX_CNT_UNIT=2
    BTN_MAIL_LF2=Request Support @ TI
    BTN_PLL2_AC_REQ=RST
    BTN_PLL2_NDIV_SWRST=RST
    BTN_PLL2_SWRST=RST
    CLKIN_FREQ=122.88
    OUTCH_CH5_freq=0
    OUTCH_CH6_freq=0
    PFDPLL2_FREQ=245.76
    PLL2_CLKin_freq=122.88
    PLL2_DBL_COMBOBOX=2
    PLL2_STRG_INITVAL_PRESET=8
    VCOPLL2_FREQ=5898.24
    VCOPRESCPLL2_freq=983.04
    VCXOPLL2_FREQ=122.88
    BTN_CH10_SWRST=RST
    BTN_CH10_SWRST_SHOW=RST
    BTN_CH1_SWRST=RST
    BTN_CH1_SWRST_SHOW=RST
    BTN_CH2_SWRST=RST
    BTN_CH2_SWRST_SHOW=RST
    BTN_CH34_SWRST=RST
    BTN_CH34_SWRST_SHOW=RST
    BTN_CH5_SWRST=RST
    BTN_CH5_SWRST_SHOW=RST
    BTN_CH6_SWRST=RST
    BTN_CH6_SWRST_SHOW=RST
    BTN_CH78_SWRST=RST
    BTN_CH78_SWRST_SHOW=RST
    BTN_CH9_SWRST=RST
    BTN_CH9_SWRST_SHOW=RST
    CHANNEL1=1
    CHANNEL10=0
    CHANNEL2=1
    CHANNEL34=1
    CHANNEL5=1
    CHANNEL6=1
    CHANNEL78=1
    CHANNEL9=1
    CHANNEL_SELECT=7
    CLKout10_freq=0
    CLKout1_freq=122.88
    CLKout2_freq=0
    CLKout3_freq=0
    CLKout4_freq=122.88
    CLKout5_freq=0
    CLKout6_freq=122.88
    CLKout7_freq=0
    CLKout8_freq=122.88
    CLKout9_freq=0
    VCOPRESCBOT_freq=983.04
    VCOPRESCTOP_freq=983.04
    btnApplyToChannel=Apply to selected Channel
    lblApplyToChannel=Function is only supported for Singlechannel as Reference
    SPI_SCL_EN_INSTAGE=1
    SPI_SCS_EN_INSTAGE=1
    SPI_SDIO_EN_INSTAGE=1
    PLL2_REF_STATCLK_DIV_COPY=0
    STATUS0_EN_INSTAGE=0
    STATUS0_OUTPUT_DATA=0
    STATUS1_EN_INSTAGE=0
    STATUS1_OUTPUT_DATA=1
    SYNC_EN_INSTAGE=1
    SYNC_OUTPUT_DATA=0
    CLKINSEL1_EN_INSTAGE=1
    BTN_LOAD_DEVICE=Load from Device
    BTN_PLL1_BW_APPLY=Apply to Device
    BTN_PLL1_FIND_BW=Find Bandwidth
    BTN_PLL1_PLOT_CL=Plot Close Loop
    BTN_PLL1_PLOT_OL=Plot Open Loop
    BTN_SUGGEST_PLL1=Find PLL1 Settings
    DEBUG_PR=0
    LF_CEXTR=4.7
    LF_ERROR_BOX=Error in Inputs, Please check Divider Values
    LF_FND_BW=38.9000000000006
    LF_FVCXO=122.88
    LF_INPUT_F=10
    LF_INPUT_MODE=1
    LF_INTG=10
    LF_NDIV=1536
    LF_PFD_F=0.08
    LF_PLL_BW=3
    LF_PROP=33
    LF_RDIV=125
    LF_VCXO_GAIN=1
    BTN_LOAD_DEVICE_PLL2=Load from Device
    BTN_PLL2_BW_APPLY=Apply to Device
    BTN_PLL2_FIND_BW=Find Bandwidth
    BTN_PLL2_PLOT_CL=Plot Close Loop
    BTN_PLL2_PLOT_OL=Plot Open Loop
    BTN_SUGGEST_PLL2=Find PLL2 Settings
    DEBUG_PR2=.
    DEBUG_PR3=0
    LF2_CFILT=0
    LF2_CPROP=0
    LF2_ERROR_BOX=Error in inputs. VCO frequency out of range.Please check your Inputs.
    LF2_FND_BW=98
    LF2_FTREE=983.04
    LF2_FVCO=5898.24
    LF2_INPUT_F=122.88
    LF2_INPUT_MODE=2
    LF2_INTG=0
    LF2_NDIV=4
    LF2_PFD_F=245.76
    LF2_PLL_BW=100
    LF2_PRE=3
    LF2_PROP=2
    LF2_RDIV=20
    LF2_RFILT=0
    BTN_FREQ_CALC=Find Solution
    BTN_PLL_FREQ_GO=Select
    FREQ1=122.88
    FREQ2=0
    FREQ3=122.88
    FREQ4=0
    FREQ5=0
    FREQ6=0
    FREQ7=0
    FREQ8=0
    FREQ_CLKIN=10
    FREQ_VCXO=122.88
    F_CALC_ERROR=0
    PFD1_1=0.08
    PFD1_10=0
    PFD1_11=0
    PFD1_12=0
    PFD1_2=0
    PFD1_3=0
    PFD1_4=0
    PFD1_5=0
    PFD1_6=0
    PFD1_7=0
    PFD1_8=0
    PFD1_9=0
    PFD2_1=245.76
    PFD2_10=0
    PFD2_11=0
    PFD2_12=0
    PFD2_2=0
    PFD2_3=0
    PFD2_4=0
    PFD2_5=0
    PFD2_6=0
    PFD2_7=0
    PFD2_8=0
    PFD2_9=0
    S10DBL=0
    S10NDIV1=0
    S10NDIV2=0
    S10PRE=0
    S10RDIV1=0
    S10RDIV2=0
    S10RDIV2_4=0
    S11DBL=0
    S11NDIV1=0
    S11NDIV2=0
    S11PRE=0
    S11RDIV1=0
    S11RDIV2=0
    S12DBL=0
    S12NDIV1=0
    S12NDIV2=0
    S12PRE=0
    S12RDIV1=0
    S12RDIV2=0
    S1DBL=1
    S1NDIV1=1536
    S1NDIV2=4
    S1PRE=6
    S1RDIV1=125
    S1RDIV2=1
    S2DBL=0
    S2NDIV1=0
    S2NDIV2=0
    S2PRE=0
    S2RDIV1=0
    S2RDIV2=0
    S3DBL=0
    S3NDIV1=0
    S3NDIV2=0
    S3PRE=0
    S3RDIV1=0
    S3RDIV2=0
    S4DBL=0
    S4NDIV1=0
    S4NDIV2=0
    S4PRE=0
    S4RDIV1=0
    S4RDIV1_2_0=0
    S4RDIV2=0
    S5DBL=0
    S5NDIV1=0
    S5NDIV2=0
    S5PRE=0
    S5RDIV1=0
    S5RDIV2=0
    S6DBL=0
    S6NDIV1=0
    S6NDIV2=0
    S6PRE=0
    S6RDIV1=0
    S6RDIV2=0
    S7DBL=0
    S7NDIV1=0
    S7NDIV2=0
    S7PRE=0
    S7RDIV1=0
    S7RDIV2=0
    S8DBL=0
    S8NDIV1=0
    S8NDIV2=0
    S8PRE=0
    S8RDIV1=0
    S8RDIV2=0
    S9DBL=0
    S9NDIV1=0
    S9NDIV2=0
    S9PRE=0
    S9RDIV1=0
    S9RDIV2=0
    SOL_SEL=0
    S_1=1
    S_10=10
    S_11=11
    S_12=12
    S_2=2
    S_3=3
    S_4=4
    S_5=5
    S_6=6
    S_7=7
    S_8=8
    S_9=9
    VCO_1=5898.24
    VCO_10=0
    VCO_11=0
    VCO_12=0
    VCO_2=0
    VCO_3=0
    VCO_4=0
    VCO_5=0
    VCO_6=0
    VCO_7=0
    VCO_8=0
    VCO_9=0
    VCXO_1=122.88
    VCXO_10=0
    VCXO_11=0
    VCXO_12=0
    VCXO_2=0
    VCXO_3=0
    VCXO_4=0
    VCXO_5=0
    VCXO_6=0
    VCXO_7=0
    VCXO_8=0
    VCXO_9=0
    Could you provide the correct configuration file to me?
    Please see the below updated configuration file for 10MHz input reference at CLKin0 input.
    LMK04610_10M_CLKin0_PLL1.tcs
    Thanks!
    Ajeet Pal
  • Dear Ajeet,
    I try the LMK04610_10M_CLKin0_PLL1.tcs configure file, but didn't lock on PLL1.
    The Loop filter used a 4.7uF capacitor on PLL1.
    Could you provide another to configure the file?
    Thank you.
    Are you using LMK04610EVM or your board to validate the device?
    The provided configuration file was tested on default LMK04610EVM. So it should work properly on EVM or board (if there is no change on circuit).
    Thanks!
    Ajeet Pal
  • Dear Ajeet,
    I used self-board to validate. I didn't EVM board on hand.
    Thank you.
    I think, we need to look on schematic of your board. How the inputs and status pins are routing and termination provided?
    Can you cross check your schematic with LMK04610EVM details or/and share with here to have a look?
    Thanks!
    Ajeet Pal
  • Dear Ajeet,
    If the device initial to finish then turn off and turn on the 10 MHz clock is entered PLL lock. If the 10MHz reference clock keeps working will be a flash of lock.
    How do they modify configure or procedure to stability to work?
    I would be suspecting 10MHz reference input level and slew rate at CLKin0 port. Is your 10MHz input following the input requirements?
    For sinusoidal input signal, you may need to feed more power to maintain its slew rate requirement also. If differential input then it should square wave which meets its requirement.
    Thanks!
    Ajeet Pal
  • Dear Ajeet,
    If setting PLL1_LOL_NORESET to Enable has been working for the lock of PLL1.
    The phase noise 1KHz to 1MHz is 3.4mDeg, Jitter is 78.08fs.
    If want to get more performance of phase noise.  How to modify configure?
    Thanks for your help.
    With PLL1_LOL_NORSET --> 1, yes, it would work same as you mentioned above turned off and on 10MHz and it locks. i.e. when PLL1_LOL_NORSET  set to 1, it will not reset the PLL when loss of lock.
    Have you checked with increasing the 10MHz reference input power?
    The above mentioned jitter is at what frequency?
    Thanks!
    Ajeet Pal
  • Dear Ajeet,
    I have been to check input power 1Vp-p.
    The jitter mentioned jitter at 122.88MHz.
    SJ
    If the input signal is sinusoidal then I would suggest to increase the power by 10/12dBm and see the performance.
    At your required integration bandwidth for jitter calculation, it would depends on the phase noise performance of used VCXO and PLL2 loop filter optimization.
    For PLL2 loop filter, I would recommend using TICS Pro loop filter calculator page to handle the loop filter settings first for your evaluation and reach out to TI  if there are any issues.
    Thanks!
    Ajeet Pal
