LMX2594: LMX2594 Phase hit issues
Part Number: LMX2594
Hi team,
Have you ever had phase hit issues with the LMX2594 ?
Do you have any suggestions why I might be experiencing phase hit problems with the LMX2594 ?
Can you suggest any help?
Best regards.
Shinji Nagamine
  • Hi Shinji-san,
    Could you be more specific what phase hit issue you are experiencing? A description of your operation procedure and some test plots will be helpful for us to understand your problem.
  • Hi Noel,
    I'm using LMX2594 for local oscillator on our wireless equipment.
    Now, I'm investigating about bit error which is occurred during temperature changes from +10ºC to -10ºC.
    bit error is occurred while lowering the temperature.
    bit error isn't occurred while rising the temperature.
    bit error isn't occurred at constant temperture.
    This phenomenon is also occurred on the mesurement of the atttached blockdiagram.
    So,I think that phase-hits of LMX2594 might be one of the causes.
    Please tell me whether LMX2594 might occur phase-hits.
    I would like any suggestions to prevent phase-hits or to reduce phase-hits.
    Setting for our board is below.
    The output frequency is 10408MHz.
    The phase detector frequency is 100MHz.
    The register configuration is attached.
    R112  0x700000
    R111  0x6F0000
    R110  0x6E0000
    R109  0x6D0000
    R108  0x6C0000
    R107  0x6B0000
    R106  0x6A0007
    R105  0x690000
    R104  0x680000
    R103  0x670000
    R102  0x660000
    R101  0x650000
    R100  0x640000
    R99  0x630000
    R98  0x620000
    R97  0x610800
    R96  0x600000
    R95  0x5F0000
    R94  0x5E0000
    R93  0x5D0000
    R92  0x5C0000
    R91  0x5B0000
    R90  0x5A0000
    R89  0x590000
    R88  0x580000
    R87  0x570000
    R86  0x560000
    R85  0x550000
    R84  0x540000
    R83  0x530000
    R82  0x520000
    R81  0x510000
    R80  0x500000
    R79  0x4F0000
    R78  0x4E016F
    R77  0x4D0000
    R76  0x4C000C
    R75  0x4B0800
    R74  0x4A0000
    R73  0x49003F
    R72  0x480000
    R71  0x470081
    R70  0x46C350
    R69  0x450000
    R68  0x4403E8
    R67  0x430000
    R66  0x4201F4
    R65  0x410000
    R64  0x401388
    R63  0x3F0000
    R62  0x3E0322
    R61  0x3D00A8
    R60  0x3C03E8
    R59  0x3B0001
    R58  0x3A8001
    R57  0x390020
    R56  0x380000
    R55  0x370000
    R54  0x360000
    R53  0x350000
    R52  0x340820
    R51  0x330080
    R50  0x320000
    R49  0x314180
    R48  0x300300
    R47  0x2F0300
    R46  0x2E07FD
    R45  0x2DC8C0
    R44  0x2C3FA3
    R43  0x2B0008
    R42  0x2A0000
    R41  0x29000C
    R40  0x280000
    R39  0x270064
    R38  0x260000
    R37  0x258404
    R36  0x240068
    R35  0x230004
    R34  0x220000
    R33  0x211E21
    R32  0x200393
    R31  0x1F03EC
    R30  0x1E318C
    R29  0x1D318C
    R28  0x1C0488
    R27  0x1B0002
    R26  0x1A0DB0
    R25  0x190C2B
    R24  0x18071A
    R23  0x17007C
    R22  0x160001
    R21  0x150401
    R20  0x14F848
    R19  0x1327B7
    R18  0x120064
    R17  0x11012C
    R16  0x100080
    R15  0x0F064F
    R14  0x0E1E70
    R13  0x0D4000
    R12  0x0C5001
    R11  0x0B0018
    R10  0x0A10D8
    R9  0x091604
    R8  0x082000
    R7  0x0740B2
    R6  0x06C802
    R5  0x0500C8
    R4  0x041943
    R3  0x030642
    R2  0x020500
    R1  0x01080B
    R0  0x002414
    Our schematic and board layout is confidential information.
    So, I would like to send it by email or something private messenger.
    Best regards.
    Shinji Nagamine
  • Hi Nagamine-san,
    Did you check the output of LMX2954 while the temperature change?
    Regarding the configuration, couples of change are recommended.
    Since your fpd is 200MHz, FCAL_HPFD_ADJ should be 0x2. Your reference clock is 100MHz, CAL_CLK_DIV should be 0x0. We can put ACAL_CMP_DLY below 25, that would reduce the calibration speed.
    You are not using any vco calibration assist, we suggest make VCO_SEL (Start VCO7) = 0x4 and VCO_CAPCTRL_STRT (Start Capcode) = 0x1.
