LMK5B12204: Is there programming order for the registers?
Part Number: LMK5B12204
I am going to try testing the h/w board with this IC.
I configured TICS Pro according to our requirements and got the *.tcs file and hexRegisterValues.txt file with successfully.
There are lots of registers to be configured, but it seems to me that there is no sequence requirement to program those registers, which is not quite sure.
So, would you like to inform us how to program those registers? Is there some registers should be programmed before any other registers or reversely?
And if we need to change the clock output on the fly, then do we need program the register of R12's RESET_SW bit after setting up other registers?
Thank you
