Part Number: LMX2572EVM
Dear forum members
we are phase coherent switching between two frequencies using the LMX2572EVM.
We facilitated it in software through toggling VCP_PHASE_SYNC_EN:
Thank you Nikolaus
Dear forum members
Thank you Nikolaus
Hello Noel,
yes I tried this but it is still not working - should my signal on the Phase Sync pin be high (3.3V) all the time? Also to double check, the Phase Sync Pin is the SMA connector next to the power in?
Again this only works if I switch the VCP_PHASE_SYNC_EN.
Thank you for your help, Nikolaus
Hi Nikkolaus,
Yes, pull HIGH the SYNC pin either by checking the SYNC box in TICS Pro:
Or provide a HIGH signal to the SYNC SMA connector.
