Part Number: LMX2592
Other Parts Discussed in Thread: LMX2594
Hi all
Would you mind if we ask LMX2592?
Comparied with LMX2594's description of Recommended Initial Power on Programming Sequence,
in case of using LMX2592, it seems that it is not neccessary to insert "Wait 10ms".
So, just in case, when we use LMX2592, we don't insert "Wait 10ms" between "4. Program the remaining registers" and "4. Program the remaining registers".
Is our recognition correct?
Then, why does LMX2594 require to insert "Wait 10ms"?
Is it relation to "REVERSE order from highest to lowest"?
<LMX2592's description>
<LMX2594's description>
Kind regards,
Hirotaka Matsumoto
